blueprint
Järv
- Moderator
- Woonplaats: Botlek
Dat is een engelse term voor het weer op fabrieksspec brengen van de motor.... reviseren zeg maar.
... eh ... is wat ze mij vroeger ooit eens hebben verteld
trouwens ... waar hebbie dat vandaan?
m.a.w. is het verkoop praat of heb je het van iets of iemand die serieus genomen kan worden (voor het geval dat... Dutch & Mista T hou jullie muil)
Laatst gewijzigd door Järv op di aug 05, 2008 1:43 pm, 1 keer totaal gewijzigd.
- Woonplaats: Nieuwegein
FF van wikipedia afgehaald:
Blueprinting
In engine blueprinting, all the specifications are double-checked. Usually this indicates closer-than-factory tolerances, with custom specifications appropriate for a street car or a race car. The goals usually are to:
Ensure the engine puts out the rated power (because not all mass-production engines put out the rated power) for its manufacturer's design
or
Make more power out of a given engine design, by extra careful measurement and assembly
balancing of reprocating parts and rotating assemblies, to reduce engine vibrations thus achieving more power due to recover of power "lost" to vibrations
Ideally, blueprinting is performed on components removed from the production line before normal balancing and finishing. If finished components are blueprinted, there is the risk that the further removal of material will weaken the component. However, lightening components is generally an advantage in itself provided balance and adequate strength are both maintained, and more precise machining will in general strengthen a part by removing stress points, so in many cases performance tuners are able to work with finished components.
For example, an engine manufacturer may list a piston ring end-gap specification of 0.003 to 0.005 inches for general use in a consumer automobile application. For an endurance racing engine which runs hot, a "blueprinted" specification of 0.00045 to 0.00050 may be desired. For a drag-racing engine which runs only in short bursts, a tighter 0.00035 to .00040 inch tolerance may be used instead. Thus "Blueprint" can mean tighter or looser clearances, depending on the goal.
wolter
Maar dat het op de site van 118GTR staat wil nog niet zeggen dat ook jou blok geblueprint is. Wat hij daar heeft staan gaat over de blokken in zn racer(s)
2008/2009 Rover 114 si '94
2013/.... Rover 200 BRM '99
Dat zegt hij toch ook niet.Smurfing schreef:Maar dat het op de site van 118GTR staat wil nog niet zeggen dat ook jou blok geblueprint is. Wat hij daar heeft staan gaat over de blokken in zn racer(s)
damn... ... alsof ik dat soort opmerkingen zal maken op dit forum.........Rover schreef: m.a.w. is het verkoop praat of heb je het van iets of iemand die serieus genomen kan worden (voor het geval dat... Dutch & Mista T hou jullie muil)
Just to be sureMark16v schreef: Dat zegt hij toch ook niet.
wolter
Mean Green
Het gaat idd om meten en de toleranties terug brengen. Als vb zijn de zuigers in dat race-blok exact even zwaar. Er zit namelijk nogal wat variantie in het gewicht van std zuigers.
In het klassement waarvoor de auto zijn opgebouwt moeten std zuigers worden gebruikt en mocht het gewicht dus niet aangepast worden(dit gebeurd in een normaal raceblok als hij uitgebalanceerd wordt). Dus namen ze 1000 zuigers en namen ze de 4 die kwa gewicht het dichts bij elkaar zaten.
Dit doe je dan met elk onderdeel en je hebt een blok dat is geblueprint, alle maten en gewichten sluiten zo strak mogenlijk.
Het resultaat is balans, het blok mag 8000rpm draaien terwijl een standaard blok niet voorbij de 6750 mag.
wolter
Dino
Normaal gesproken heb je ook geen 1000 zuigers nodig hoor, dat was alleen om het reglement te omzeilen. er moesten namelijk std zuigers worden gebruikt.
Het gaat om die verschillen en meetingen, een normaal geblueprintblok heeft gewoon zuigers die uitgewogen zijn.
