ZS180 neer op Macht??
ZS180 neer op Macht?? kwamen wij over een probleem met KV6'S de andere dag bij de rollende weg waar ZS180'S neer op macht waren.
De fout werd aan de plastic dia in de inhamverzamelleiding gevonden die geplakt wordt aangezien het zich van links naar rechts bewoog.
Om dit te controleren zult u de inspectiedekking voor wat moeten openen als een sqauredoos kijkt die aan de linkerkant van de inhamverzamelleiding zit. neem de 4 schroeven van Philips en conecter die in het doosdeksel stopt, binnen is een bruin spoor dat,if gemakkelijk van links naar rechts zou moeten bewegen het lichtjes spay met één of andere omhoog WD40 aan vrij het vangt en dit de truc zou moeten doen.
Kev
Kev
Hah, i think it'll be easier for us to read if you just posted it in english. These are certainly dutch words but the spelling isn't quite correct. Very hard to understand what it says, for me at least..
I think it has something to do with the ZS180 being "down on power". Something inside the inlet plenum that's stuck, and needs to be freed with the help of some WD40???
- Moderator
- Woonplaats: Botlek
Yea ... I come as far as that there is a movable piece of plastic that is obstructing something and causes power loss of the KV6 engine.
Which you can solve by undo some screws somewhere and do something.
Or was it to screw somewhere? ... but that would be a pleonasm coz yer allready doin something then
Cheers mate,
Dennis
Cheers mate,
Dennis
"These are certainly dutch words but the spelling isn't quite correct. Very hard to understand what it says, for me at least.."
Sorry ,the translation tool had trouble changing cockney into dutch
here goes,i was having a bevy down the rub a dub with me old mucker when i said the jam jar was a bit tom & dick.Tom & dick he says "yes,its a few ponies shy of what it allta be". he says get on the dog and have a chin wag with george and thats what i did
Basicly that plastic slider controls the torque (variable inlet manifold),and if it dont slide freely or the small motor that controls it dont work propely iy will effect the power,it will seem like theres a flat spot on the power range or in my case only achieve maximum power @5500 which is 1000 rpm short of what it should be.
HTH Kev
HTH Kev
- Striker
ZS180SX schreef:here goes,i was having a bevy down the rub a dub with me old mucker when i said the jam jar was a bit tom & dick.Tom & dick he says "yes,its a few ponies shy of what it allta be". he says get on the dog and have a chin wag with george and thats what i did
Nice to see you posting here again Kev
- Striker
Can you email it to me: striker@mg-r.nl ?
I hope Kev has sorted his problems now, every time I read his post I think my Dutch is even worse than it is.
You asked Kev to write in English to you, so I am following your advice to him
for ZS lovers, here is a sad sight of a pretty badly-crashed car. Looks like the driver got away OK though.
http://www.mg-rover.de/go.to/modix/2,1, ... wagen.html
just look how beautiful this car is from the back...
pat
pat
