Het een en ander over NoS
Geplaatst: za aug 16, 2003 10:29 pm
door Järv
NITROUS OXIDE GENERAL &
TECHNICAL INFORMATION
( Zie ook: NOS-Tech 1 t/m NOS-Tech 6 )
Types of NOS Systems
An Overview Of Wet, Dry And Direct Port Systems
These are three basic types of nitrous systems: dry, wet, and direct port. The most misunderstood is the "dry" type of system. A "dry" nitrous system simply
means that the fuel required to make additional power with nitrous will be introduced through the fuel injectors (remember, fuel makes power, nitrous simply lets you burn more of it). This keeps the upper intake dry of fuel. We accomplish this by two methods. First, is to increase the pressure to the injectors by applying nitrous pressure from the solenoid assembly when the system is activated. This causes an increase in fuel flow just like turning up the pressure on your garden hose from 1/2 to full. The second way we can add the required fuel is to increase the time the fuel injector stays on. This is accomplished by changing what the computer sees, basically tricking the computer into adding the required fuel. In either case, once the fuel has been added, the nitrous can be introduced to burn the supplemental fuel and generate additional power.
The second type of nitrous kit is the "wet" style of kit. These kits include carburetor plate systems and add nitrous and fuel at the same time and place (normally 3-4" ahead of the throttle body for fuel injected applications or just under the carb as with plate systems). This type of system will make the upper intake wet with fuel. These systems are best used with intakes designed for wet flow and turbo/supercharged applications.
The last type of system is the direct port system. Just as it's name implies, it introduces the nitrous and fuel directly into each intake port on an engine. These systems will normally add the nitrous and fuel together through a fogger nozzle or a NOSzleTM. The fogger nozzle mixes and meters the nitrous and fuel
delivered to each cylinder. This is the most powerful and one of the most accurate type of systems. This is due to the placement of the nozzle in each runner, as well as the ability to use more and higher capacity solenoid valves. A direct port system will have a distribution block and solenoid assembly which delivers the nitrous and fuel to the nozzles by way of connecting tubes. Because each cylinder has a specific nozzle and jetting (both nitrous and fuel), it is possible to control the nitrous/fuel ratio for one cylinder without changing that of the other cylinders. These systems are also one of the more complicated systems when installation is considered, as the intake must be drilled, tapped, and the "plumbing" made to clear any existing obstructions. Because of this and the high output of these systems, they are most often used on racing vehicles built for the strain of such high horsepower levels.
Tuning Technical Information
Nitrous System Theory, Selection, and Tuning
As modern engines become more difficult to modify, the use of nitrous oxide to obtain phenomenal performance gains is on the rise and for good reason. We firmly believe that our nitrous systems and related products are the highest quality, performance, and value available anywhere in the world. We can make this claim because we've been manufacturing nitrous systems and components since 1978. The value of this to you is the vast experience we have accumulated throughout the history of our company.
Among the many true bolt-on performance enhancing products available, there are few that can even come close to comparing to the dramatic results of a power increase provided by one of our nitrous systems. In both the simplicity and reliability that you get when you install a nitrous system that carries our world-famous NOS logo, you'll be amazed at how easy it is to produce the one thing everyone is always searching for more of...POWER!
When you consider all of the options you have to get an engine to release all of the potential power it can, there is no equal to the ability nitrous oxide provides you. If you look at a nitrous oxide system on a dollar-per-horsepower basis, you'll find that a nitrous system from NOS can provide the greatest value for each dollar of your precious investments. Our experience throughout the years has proven to us that performance enthusiasts and racers alike are most impressed by the ability to add 10 to 200 horsepower within a period of just a few hours. By carefully choosing the correct system for your applications, you'll be assured of a performance increase and reliability factor that could only be compared to doubling the size of your engine by simply activating your NOS nitrous system!
How to Make Horsepower
An engine operates by burning fuel, which then expands and pushes the pistons down. Want to make more horsepower? Burn more fuel so it will push the pistons down with more force. Sounds pretty simple. But, it's not quite so easy. While there are any number of factors that make increasing power a complex engineering problem, we will deal with three of the most basic ones here.
First, all fuels require oxygen in order to burn. If you want to burn more fuel, you need to also put in more oxygen. Virtually all engine performance products increase power by increasing the flow of fuel and oxygen. Camshafts, larger carburetors or valves, porting, intake manifolds, exhaust headers, superchargers, turbochargers, and nitrous oxide are clear examples of how improved engine breathing (putting in more oxygen in order to burn more fuel) will give you an increase in horsepower. Nitrous oxide injection systems are probably the most efficient way to increase the flow of oxygen and fuel. That's the basic reason why nitrous systems produce such large horsepower increases.
Another basic power factor is vaporization of the fuel. Gasoline, as with other racing fuels, will not burn in a liquid state. The gasoline must be turned into a vapor for it to burn. This process of turning gasoline into a vapor is simple evaporation. It is basically no different from setting a glass of water outside and waiting for it to dry up. In the engine, of course, evaporation happens very quickly. Engine heat and fuel atomization are the keys to accelerating the evaporation process enough to turn raw gasoline into a vapor at 8000 RPM. The process of atomization turns raw fuel flow into tiny droplets which then evaporate faster due to the larger amount of surface area presented for evaporation. The size of the fuel droplets is very important. Take a large droplet of gasoline, break it up into 10 smaller droplets, and you've increased the surface area for more efficient evaporation. The result is more fuel available to be burned and do work during combustion. A well-designed nitrous system will produce very small droplet sizes in the supplemental fuel that flows into the engine with nitrous. This is one of the reasons that NOS nitrous systems can make more horsepower than some other systems.
The third basic power factor we will look at is air/fuel mixture density. Ever try to jog on top of a 10,000 foot pass in the Rockies? Leaves you gasping for breath, doesn't it? That's because the air is thinner, less dense, higher up in the atmosphere than it is at sea level. It is also why you would run slower on a track in Denver than you would near sea level in New Jersey. Density is affected by atmospheric pressure (the weight of the atmosphere above you), heat, and humidity. We can't change the pressure of the atmosphere; but we can regulate the heat of our intake charge to some extent. Cool cans and intercoolers make extra power by cooling the fuel and air/fuel mixture to make it denser. And, the denser the mixture is, the more the cylinder is packed with fuel and air to burn and make power. When nitrous oxide is injected, it turns from a liquid to a gas instantly and becomes very cold. This cold nitrous vapor drops the temperature of the whole intake charge in the manifold by as much as 65 degrees F. The denser mixture that results helps an engine produce even more extra horsepower with a nitrous system.
What Nitrous Oxide Is and What Nitrous Oxide Isn't
To your engine, nitrous oxide is a more convenient form of normal air. Since we are only interested in the oxygen the air contains, nitrous oxide provides a simple tool for manipulating how much oxygen will be present when you add additional fuel in an attempt to release more power. The power always comes from the fuel source. Nitrous oxide is not a fuel. Nitrous oxide is a convenient way to add the additional oxygen required to burn more fuel. If you add only nitrous oxide and do not add additional fuel, you would just speed up the rate at which your engine is burning the fuel that it normally uses.
This, more often than not, leads to destructive detonation. The energy comes from the fuel, not the nitrous. Nitrous oxide simply allows you to burn a greater quantity of fuel in the same time period; thus, the overall effect is a tremendous increase in the total amount of energy, or power, released from the fuel and available for accelerating your vehicle.
There is no voodoo involved in nitrous oxide. In effect, using nitrous is no different from using a bigger carburetor, a better manifold, a supercharger, or a turbocharger. Understand that the air you and your engine breathe is made up, at sea level, of 78% nitrogen, 21% oxygen, and just 1% other gases. Nitrous oxide (N2O) is made by simply taking the 2 major components of earth's atmosphere (in this case 2 molecules of nitrogen and 1 molecule of oxygen) and attaching them together with a chemical bond. When the nitrous oxide goes into your engine the heat of combustion breaks the chemical bond to provide your engine more oxygen with which to burn fuel. As you've read, all race engines operate under the same principles: more air (better breathing, supercharging, turbocharging, or nitrous) plus more fuel in a denser vapor equals more power.
Nitrous Oxide vs. Other Performance Products
Dollar for dollar, nitrous oxide offers the most performance a consumer can buy. You could spend thousands of dollars on carburetion, a manifold, valve train components, exhaust, pistons, porting, supercharging, or turbocharging to get the same amount of extra horsepower that a nitrous system would provide for just a few hundred dollars. But this doesn't mean you won't benefit if you also install other performance parts. Once you have installed a nitrous system, all those other performance parts just increase the nitrous power. If you just have a few dollars and want lots of extra power, the best choice is an NOS nitrous system.
Only nitrous is a part time power increaser. All of the standard performance parts put additional stress on the engine and burn more fuel all the time; not to mention what a pain it is to ride around town with a lumpy idle from a camshaft that is barely streetable. Power on demand is one of the great things about a nitrous system; it only works when the driver wants it. All the rest of the time, the engine operates normally; no extra stress, no extra fuel use, and no driveline problems.
What You Get When You Buy a Nitrous Oxide System from NOS
Of all the components in your NOS system that you see when you take it out of the box, there are three things that you may not fully recognize until you have gone through the installation process and used your NOS system for the first time.
Integrity. We stand behind our products. If we claim a system is capable of 100 horsepower, it's because we designed it that way, tested it that way, and manufactured it that way. If you are willing to follow our guidelines, you'll get the results that we say you'll get.
Quality. There are a lot of things we do everyday here at NOS. We test our products and systems on sophisticated measuring equipment as well as the real-world environment of the vehicle it's intended for. We pay strict attention to the manufacturing procedures required to maintain our high standards for components. We listen to what you have to say about the performance of our products along with your suggestions for new applications. Our Tech staff relays your comments to our research and development staff to constantly re-evaluate all products to ensure they are up to date and effective for the intended application.
Experience. We have been manufacturing nitrous oxide systems for over twenty years. We have learned from our successes as well as our failures. We take this knowledge and apply it in very heavy doses to the products we design and manufacture. Even though today may be the very first day that you have installed and used one of our systems, you've got twenty years of nitrous experience with you every step of the way. It's there in the box. You may not see it; but you'll definitely feel it.
Nitrous Oxide and Emissions
Use of nitrous oxide (N2O) doesn't necessarily increase the oxides of nitrogen (NOx) that pollute the air. Of course, NOS makes "race only" systems that are not legal for use on pollution controlled engines. However, many NOS systems have received certification for 50-state emissions legal use in the United States. The approvals for use on emissions controlled vehicles were obtained by independent laboratory testing which proved that these NOS systems do not increase tailpipe emissions in normal driving conditions. We recommend only emissions legal nitrous kits for use on engines subject to emissions and regulations.
Types of Nitrous Oxide Systems
The two most popular types of nitrous oxide systems are spray bar plate systems, such as the Powershot, Cheater, and Big Shot automotive systems (which use a spacer plate between the carburetor and manifold) and direct port. The plate adds nitrous and supplemental fuel to the intake air stream through built-in spray bars. Plate systems are used on automotive engines on the street and in many racing classes.
Direct port systems use specially designed injectors, FoggerTM nozzles, to add the nitrous and supplemental fuel to each individual intake runner. These systems can flow huge amounts of nitrous and fuel while distributing it evenly to every cylinder. Multiple stage direct port systems have produced much more than 500 extra horsepower on some pro racing engines. All NOS Direct Port systems feature changeable nitrous and fuel jets for horsepower adjustments and system tuning. Direct port systems are used in both street and racing applications on virtually every kind of engine. Some nitrous systems for fuel injection are a variation of Direct Port technology.
Tuning Your NOS System:
A Few Important Points to Remember
Although this may seem like a very basic factor, failure to thoroughly read the instructions is the number one reason your system installations will not be successful. Read ALL the instructions included with your system BEFORE you do anything at all! You may find that you need to change something on your engine or find that we've designed something new that is different from some of the systems you may have seen in a magazine article. Save time and headaches by taking the time to thoroughly read all of the instructional materials.
Always start conservative. Follow our recommended jet combinations and start with the lowest level if you have an adjustable system. It only takes a few moments to change the jets so don't take unnecessary risks by starting at the highest level.
Be realistic about how much power your engine will handle. Don't get carried away here. Only you know exactly which components are in your engine. If you are unsure about those components, you can call our tech line and one of our highly experienced tech personnel can help you to decide what is safe for your particular combination. If you don't know what's inside your engine, then you are most safe by assuming that the components are factory stock and choose the correct system for that application.
The power comes from fuel. The additional power is set by the amount of additional fuel your system supplies while the nitrous system is in operation. If the fuel isn't there, the power won't be either and no amount of nitrous or anything else can bring it back. There are two controls typically available to manipulate the amount of fuel available during system use; the fuel jet size and the fuel pressure. The correct fuel pressure is read while the system is flowing fuel. Some fuel pressure regulators give false readings because the pressure reading will creep up when the system is not activated. When this happens, the actual flowing fuel pressure will be much lower than expected and can cause problems.
When problems with misfire or detonation are encountered, ALWAYS reduce the size of the nitrous jet first! Remember that the power comes from the fuel, not the nitrous, so trying to cool things down by adding fuel simply adds more power and complicates the problem. Carburetors jetted over-rich run cooler and release less power. Nitrous systems jetted over-rich will possibly just release more power, so if you run into problems, reduce the size of the nitrous jet(s) first.
When you check your spark plugs for signs of how your system is operating, CHECK EVERY SPARK PLUG, not just the easiest plug to get to. No two cylinders ever run exactly alike. Nitrous has the unique characteristic of cleaning the spark plugs very well and leave them looking like you just installed them. If there are any signs of detonation such as tiny silver or black specks deposited on the porcelain, reduce the nitrous jet size. If the ground strap of the spark plug exhibits a bluish-rainbow coloring, reduce the nitrous jet size. If the ground straps shows signs of melting, reduce the nitrous jet size and change to a spark plug with a shorter and thicker ground strap.
If your system suddenly begins to experience problems even though you haven't changed anything, the culprit is most often a clogged nitrous or fuel filter. The instructions that come with your system contain information about where the nitrous and fuel filter screens are located. Check them periodically. NOS systems are calibrated for optimum performance with a bottle pressure of 900-950 psi. The pressure will change with temperature. NOS heater kits are thermostatically controlled to keep the bottle near 85°F to provide correct pressure. Kits available for the most popular-sized bottles, with both 12-volt and 10-volt heaters offered.
If you experience any problems you don't understand or can't cure, don't hesitate to call our tech line. We're here to help you get the most from your NOS System.
Spark Plugs and Nitrous Oxide:
What Works, What Doesn't, and Why
Over the years there seems to have been a great amount of technical material written about the simple operation of a spark plug and what they can do in relation to the way an engine runs. There are a few basic characteristics about spark plugs that you need to know to make an intelligent choice about the correct spark plug for your application.
First, and most important; a spark plug must be of the correct design to operate within the environment of your engine, not the other way around. This means that the spark plug has virtually no influence on how the engine burns fuel or runs in general. The correct spark plug will simply survive the conditions present in your engine. A spark plug must maintain a certain temperature to keep itself clean. The wrong heat range can cause an overheated plug or a fouled plug. The heat range refers to the temperature of the ceramic material surrounding the center electrode.
Lean air/fuel ratios are more difficult to light because there are less fuel molecules in the area of the plug gap when the plug is scheduled to fire; thus, projected nose plugs were designed for late-model lean-burn engines. Modern high-energy ignition also allowed larger plug gaps. All the while this was happening, something else happened. Something that no one seems to have really noticed as the real culprit when the issue of factory type plugs being used with nitrous comes up. We'd like to clue you in.
Quite often, a factory type, wide-gap projected plug will produce a misfire condition after only a few seconds of nitrous use. The misfire is not due to the heat range. The misfire occurs because the ground strap of the spark plug becomes a glowing ember because it is too long to dissipate the extra heat produced by a nitrous-accelerated burn condition. The correct fix for this phenomenon is to replace the plugs with one that has a shorter ground strap. By doing this, you will shorten the path for the heat being absorbed by the ground strap. You can use the same heat range, you just have to find a non-projected nose plus with a shorter and preferably thicker ground strap.
If you only change the heat range of the spark plug to a colder heat range, you may very well still have the misfire problem. Since the length of the ground strap is the cause of the misfire, a colder spark plug may have the same length of ground strap as the hotter plug you replaced it with.
Spark plug gaps should generally be .030" to .035". Never try to gap a plug designed for an .060" gap down to .035". Find the correct non-projected nose plug designed for an .035" gap.
NOS F.A.Q
Here are answers to the most commonly asked questions about NOS Nitrous Oxide Systems, along with tech information compiled by the NOS Research and Development Team.
There's really nothing mystical about nitrous oxide and its application for engines. Very simply, NOS made it better and safer for customer use. The following questions and answers are typical of those fielded by NOS R&D people and we hope that they will be of help to all of those who seek the winning edge.
Q: Will Nitrous affect engine reliability?
A: The key is choosing the correct H.P. for a given application. A kit that uses the correct factory calibration does not usually cause increased wear. As the energy released in the cylinder increases so do the loads on the various components that must handle them. If the load increases exceed the ability of the components to handle them, added wear takes place. NOS kits are designed for use on demand and only at wide open throttle. Nitrous can be extremely advantageous in that it is only used when you want it, not all the time. All NOS kits are designed for maximum power with reliability for a given application.
Q: Can I simply bolt a nitrous kit onto my stock engine?
A: Yes. NOS manufactures systems for virtually any stock engine application. The key is to choose the correct kit for a given application; i.e., 4 cyl. engines normally allow an extra 40-60 HP, 6 cyl. engines usually work great between 75-100 extra HP, small block V8's (302/350/400cid) can typically accept up to 140 extra HP, and big block V8's (427-454) might accept from 125-200 extra HP. These suggested ranges provide maximum reliability from most stock engines using cast pistons and cast crank with few or no engine modifications.
Q: What are some of the general rules for even higher HP gains?
A: Generally, forged aluminum pistons are one of best modifications you can make. Retard ignition timing by 4-8 degrees (1 to 1-1/2 degrees timing retard per 50 HP gain). In many cases a higher flowing fuel pump may be necessary. Higher octane (100+) racing type fuel may be required as well as spark plugs 1 to 2 heat ranges colder than normal with gaps closed to .025"-.030". For gains over 250 HP, other important modifications could be necessary in addition to those mentioned above. These special modifications may include a forged crankshaft, a high quality race type connecting rods, a high output fuel pump dedicated to feeding the additional fuel demands of the nitrous system, and a racing fuel with high specific gravity and an octane rating of 110 or more. For more specific information about your application, please contact the NOS technical dept.
Q: How does nitrous work?
A: Nitrous oxide is made up of 2 parts nitrogen and one part oxygen (36% oxygen by weight). During the combustion process in an engine, at about 572 degrees F, nitrous breaks down and releases oxygen. This extra oxygen creates additional power by allowing more fuel to be burned. Nitrogen acts to buffer, or dampen the increased cylinder pressures helping to control the combustion process. Nitrous also has a tremendous "intercooling" effect by reducing intake charge temperatures by 60 to 75 degrees F.
Q: What kind of testing or research is performed on NOS products?
A: NOS maintains a complete research and development center including computerized dynamometer equipment as well as a nitrous/fuel flow testing facility. In addition, NOS is actively involved in many aspects of racing; working closely with many top name racers to develop the most powerful and reliable nitrous systems in the world.
Q: How much performance improvement can I expect with a nitrous system?
A: For many applications an improvement from 1 to 3 full seconds and 10 to 15 MPH in the quarter mile can be expected. Factors such as engine size, tires, jetting, gearing, etc. will affect the final results.
Q: How long will the bottle last?
A: This largely depends on the type of nitrous kit and jetting used. For example, a 125 HP Power Shot kit with a standard 10 lb. capacity bottle will usually offer up to 7 to 10 full quarter-mile passes. For power levels of 250 HP, 3 to 5 full quarter-mile passes may be expected. If nitrous is only used in 2nd and 3rd gears, the number of runs will be more.
Q: How long can I hold the nitrous button down?
A: It is possible to hold the button down until the bottle is empty. However 15 continuous seconds at a time, or less, is recommended.
Q: When is the best time to use nitrous?
A: At wide open throttle only (unless a progressive controller is used). Due to the tremendous amount of increased torque, you will generally find best results, traction permitting, at early activation. Nitrous can be safely applied above 2,500 RPM under full throttle conditions.
Q: Does NOS manufacture 50-state legal nitrous systems?
A: Yes. In fact, NOS has several EO numbers for various kits such as the 5.0L Mustang and 305/350 GM V8's, etc. In addition, there is no need to remove any smog equipment when installing an NOS system. For more information call the NOS tech line.
Q: Will I have to re-jet my carburetor on my car when adding nitrous?
A: No! The NOS system is independent of your carburetor and injects its own mixture of fuel and nitrous.
Q: Is nitrous oxide flammable?
A: No. Nitrous Oxide by itself is non-flammable. However, the oxygen present in nitrous oxide causes combustion of fuel to take place more rapidly.
Q: Will nitrous oxide cause detonation?
A: Not directly. Detonation is the result of too little fuel present during combustion (lean) or too low of an octane of fuel. Too much ignition advance also causes detonation. In general, most of our kits engineered for stock type engines will work well with premium type fuels and minimal decreases of ignition timing. In racing application where higher compression ratios are used, resulting in higher cylinder pressures, a higher fuel octane must be used as well as more ignition retard.
Q: Where can I get my bottle refilled?
A: Simply call 1-800-99-REFILL for the location of the nearest NOS dealer with refilling capabilities, or check immediately for the most up-to-date Authorized NOS Refill Station Dealers List online.
Q: Is there any performance increase in using medical grade nitrous oxide?
A: None! NOS recommends and sells only the automotive grade, called Ny-trous Plus. Ny-trous Plus contains a minimal amount of sulfur dioxide (100 ppm) as a deterrent to substance abuse. The additive does not affect performance.
Q: Is it a good idea to use an aftermarket computer chip in conjunction with an NOS System?
A: Only if the chip has been designed specifically for use with nitrous oxide. Most aftermarket chips use more aggressive timing advance curves to create more power. This can lead to possible detonation. You may wish to check with the manufacturer of the chip before using it. The top manufacturers, such as Hypertech do make special chips for use with nitrous.
Q: How long does it generally take to install an NOS kit?
A: The majority of NOS kits can be installed using common hand tools in approximately 4 to 6 hours. NOS instruction manuals are by far the best in the industry; and include specific installation drawings, wiring diagrams, and bottle mounting procedures as well as performance tips and a thorough trouble shooting guide.
Q: Which type of manifold is better suited for a plate injector type of nitrous system, single or dual plane manifold?
A: As long as the manifold doesn't interfere with the spray pattern of the bars, either will work fine in most cases. The distribution is better with a single plane at high RPM. If your goal is to increase power by more than 150 HP, the single plane manifold is better.
Q: Does nitrous oxide raise cylinder pressure and temperatures?
A: Yes. Due to the ability to burn more fuel, this is exactly why nitrous makes so much power.
Q: Are there any benefits to chilling the nitrous bottle?
A: No. Chilling the bottle lowers the pressure dramatically and will also lower the flow rate of the nitrous causing a fuel rich condition and reducing power. On cold evenings you might run on the rich side. For optimal running conditions, keep bottle pressure at approximately 900-950 psi. NOS has a nitrous pressure gauge that allows you to monitor this. If you live or operate a nitrous system in colder temperatures, it may also be a good idea to purchase a bottle heater kit, part #14164. Generally, ambient temperatures of 80-90 degrees F will allow for best power potential of NOS kits.
Q: Are there benefits to using nitrous with turbo or super-charger applications?
A: Absolutely! In turbo applications, turbo lag is completely eliminated with the addition of a nitrous system. In addition, both turbo and superchargers compress the incoming air, thus heating it. With the injection of nitrous, a tremendous intercooling effect reduces intake charge temperatures by 75 degrees or more. Boost is usually increased as well, adding to even more power.
Q: How complete is an NOS kit?
A: NOS prides itself on offering the most complete systems on the market today. They include virtually every component that may be needed for a complete installation; parts such as extra long carburetor studs, gaskets, pipe tap, fuel hose, brackets, filters, fittings, hardware, wiring, 10 lb. bottle with Hi-Flo valve, comprehensive instruction manual, and all other major components are standard in every NOS kit.
Q: What is the difference between a standard and an NOS Hi-Flo bottle valve?
A: The orifice of the Hi-Flo valve is much larger than the standard valve allowing for a larger flow of nitrous. With a small orifice valve a pressure drop could occur when nitrous flow is high; causing surging or inadequate nitrous flow. The NOS Hi-Flo valve eliminates this problem. NOS Hi-Flo valves are standard in all NOS kits.
Q: What affect does nitrous have on an engine with considerable miles on it?
A: This depends largely on the actual condition of the engine components. Any performance modification to an engine that is worn out or poorly tuned will have detrimental effects. However, an engine in good condition, with good ring and head gasket sealing, should be able to use nitrous without any abnormal wear.
Q: Will the use of nitrous oxide affect the catalytic converter?
A: No. The increase in oxygen present in the exhaust may actually increase the efficiency of the converter. Since the use of nitrous is normally limited to 10-20 seconds of continuous use, there usually are no appreciable effects. Temperatures are typically well within acceptable standards.
Q: Will the percentage of performance increase be the same in a highly modified engine compared to a stock engine when using the same NOS kit and jetting?
A: Not really. In most cases the percentage of increase is greater from a stock engine because it is not as efficient as the modified engine in a normal non-nitrous mode. However, since the effects of nitrous oxide magnify the output of any engine, the total power output will be much higher in the modified engine.
Q: Can high compression engines utilize nitrous oxide?
A: Absolutely. High or low compression ratios can work quite suitably with nitrous oxide provided the proper balance of nitrous and fuel enrichment is maintained. NOS kits are used in applications from relatively low compression stock type motors to Pro-Modifieds, which often exceed 15 to 1. Generally, the higher the compression ratio, the more ignition retard, as well as higher octane fuel, is required. For more specific information talk to one of our technicians.
Q: Can service station fuel be used for street/strip nitrous oxide applications?
A: Yes. Use of a premium type leaded or unleaded fuel of 92, or greater, octane is recommended for most applications. Many NOS systems are designed for use with service station pump gas. However, when higher compression or higher horsepower levels are used, a racing fuel of 100 octane, or more, must be used.
Q: What type of cam is best suited for use with nitrous oxide?
A: Generally, cams that have less exhaust overlap and more exhaust duration. However, it is best to choose a cam tailored to normal use (when nitrous is not activated) since 99% of most vehicle operations is not at full throttle. There are special cam grinds available for nitrous competition which have more aggressive exhaust profile ramping, etc. Since cam selection depends largely on vehicle weight, gearing, etc., it is best to stick to cam manufacturers' recommendations for your particular goal.
Q: Are NOS kits applicable on late model EFI cars?
A: Yes. In fact NOS has by far the most comprehensive selection of nitrous kits available for these cars. Call for your specific application if you do not see it listed.
Q: What type of nitrous system is better; a plate injection system or a direct port injection system?
A: The advantages of a plate system are ease of installation and removal, ability to transfer easily to another vehicle, ability to change jetting combinations quickly, and in most cases, provide you with all the extra HP you will ever need (75 to 350 more HP). In some cases, such as in-line type engines with long runners, a direct port type system is advisable for maximizing distribution. Also, where more than 350 HP is needed, our direct port Fogger systems will provide the ultimate in distribution and power (up to 500+ HP). Direct port injection is also desirable when the system is hidden under the manifold.
Q: Should I modify my fuel system to use nitrous oxide?
A: Most stock fuel pumps will work adequately for smaller nitrous applications. It is important to check to see if your pump can flow enough fuel to your existing fuel system (whether carburetor or fuel injected), as well as being able to supply the additional fuel required by the nitrous kit under full throttle conditions. It may be a good idea to dedicate a separate fuel pump to the nitrous kit.
Q: Which is the best position to mount a nitrous bottle?
A: NOS bottles come with siphon tubes and, in order to maintain proper nitrous pickup, it is important to mount the bottle correctly. We recommend mounting the bottle at a 15 degree angle with the valve end higher than the bottom of the bottle. The valve end of the bottle should point to the front of the vehicle and the valve knob and label should face straight up.
Q: How important is it to use nitrous and fuel filters in a kit?
A: Some of the most important components of any nitrous system are nitrous and fuel filters. To keep contaminants from attacking the solenoid or plugging up a jet, NOS nitrous filters feature a special stainless steel mesh element from the aerospace industry.
Q: What are the advantages of using nitrous compared to other performance options?
A: The cost of many other performance options can put you in the poorhouse. Dollar for dollar, you can't buy more performance with less money than nitrous. With a nitrous system, performance and reliability can be had for a much more reasonable price while still retaining the advantage of a stock engine during normal driving. And, Nitrous offers tremendous gains in torque without having to rev the engine to excessive rpm's. These factors help your engine last longer than many other methods of boosting horsepower.
Q: Does NOS manufacture kits for motorcycles, water craft, or snowmobiles?
A: Absolutely. Call or write NOS to obtain our special catalog devoted specifically to these applications.
Q: What kind of pressures are components subject to in a typical nitrous kit?
A: Pressures often exceed 1,000 psi. This is why NOS uses only high pressure tested aircraft quality components like stainless steel braided Teflon lines throughout its system.
Q: How do I know how much nitrous is left in the bottle?
A: The most reliable method was is to weigh the bottle to determine how many pounds remain. When a bottle is near empty (about 20% or less nitrous remaining) a surging effect is normally felt.
Q: What is the function of the blow-off safety valve on the bottle?
A: It is very important not to overfill a bottle; i.e., a 10 lb. capacity bottle should not be filled with more than 10 lbs. of nitrous oxide by weight. Over-filling and/or too much heat can cause excessive bottle pressures forcing the safety seal to blow and releasing all the contents out of the bottle.
Q: Will I have to change my ignition system?
A: Most late model ignition systems are well suited for nitrous applications. In some higher HP cases, it may be advisable to look into a high quality high output ignition system.
Geplaatst: ma aug 18, 2003 11:38 am
door trampLe
en? ga je voor een nos kit?
Zo te zien ben je wel je huiswerk aan het doen!
Geplaatst: ma aug 18, 2003 5:42 pm
door Järv
Hya Big J (ex-trampLe),
Yep, druk bezig er zo veel mogelijk over te weten te komen ...
... maar of het in m'n rovert gebouwd wordt weet ik niet.
Een 25/50 PK-Kit kost in America ongeveer 350,- Dollar .. dus plusminus 350,- euries.
Hier in Nederland kost zo'n zelfde kit 1100,- EURO !!!
ofie belazerd wordt ! :evil:
Maar eerst de spoilers, Blitz C1, ramen tinten, accu omgooien, ...eh .. en nog wat dingetjes wat ik ff vergeten ben :|
Cheers,
Dennis :cool:
Geplaatst: ma aug 18, 2003 6:20 pm
door Mista T
Cheers,
Dennis :cool:
Uuuuhhhhmmmmm
T16 Blok!!!!!!?? :lol: :twisted: :shock:
grtz
Geplaatst: ma aug 18, 2003 6:25 pm
door trampLe
zo groot is een t16 blok toch niet? :mrgreen:
Geplaatst: ma aug 18, 2003 6:59 pm
door Järv
Mja een 2liter Turbo T16 ... zou wel wreed heftig zijn ja.
Rofl .. een 416Si met 200pk :mrgreen:
EN EEN DUMPVALVE !! :bangin:
Geplaatst: zo jan 11, 2004 3:32 am
Rover schreef:Rofl .. een 416Si met 200pk :mrgreen:
ik zou meteen kappen met de auto een "416Si" te noemen, hij verdient wel beter dan. 420Ti klinkt echt VEEL beter, vinden jullie niet?
Geplaatst: zo jan 11, 2004 4:01 pm
door Mista T
118GTR schreef:420Ti klinkt echt VEEL beter, vinden jullie niet?
Klopt dat dat beter klinkt......
Trouwens die is er ook wel, ook af fabriek.... Maar weer niet in NL net zoals de 620 TI....... DAMn, wat zou ik die graag hebben..................
