Voor een 1995 -- Rover 400 :
ECU locations
1. Window lift ECU (in the drivers door)
2. Multi Function Unit (MFU) - below steering wheel
3. PGM-Fi ECU - 416 Automatic only
4. SRS ECU (behind centre console)
5. Anti-theft alarm ECU & central door locking ECU (behind centre concole)
6. MEMS 1.9 (except 416 Automatic) or BOSCH ECU (in case of some Diesel)
7. ABS ECU - 416 Automatic
8. ABS ECU - except 416 Automatic
Relay locations
- In engine compartment
01. Main relay module --- to VIN WD274935 - YWB100710
----------------------- from VIN WD274936 - YWB100970
02. A/C relay module - YWB100800/1
03. Main relay - YWB100560/790 (Diesel engine only)
04. Starter relay - YWB100560/790 (Diesel engine only)
NOTE:-- to VIN WD274935 - YWB100560
------from VIN WD274936 - YWB100790
- Behined centre console
05. Rear wiper relay - YWB10032 - RH side
06. Power wash relay - YWB10027 - RH side
07. Front Fog Lamp Relay - YWB10027 - RH side
08. Cruise Relay - SCB100140 - RH side
09. Daylight Running Lights Relay - YWB10032 - RH side
10. Starter relay - YWB100630 - (416 Automatic only) - LH side
- Behined RH side of facia
11. Main relay module - YWB100590 (416 Automatic only)
12. Passanger seat relay box - YWB10050
13. Drivers seat relay box - YWB10050
- Roof
14. Sunroof relay 1 - YWB10032
15. Sunroof relay 2 - YWB10032
Honda engine 1600 Automatic gearbox ABS fusebox
Engine compartment fusebox
- Relays
1. Cooling Fan Relay (non aircon) - YWB10027
2. Heater/Blower Motor Relay - YWB10027
3. HRW Relay - YWB10027
-Fuse--Rating---Function
--A----80 amp---Main fuse
--B----50 amp---Column switch, feeds fuses 19 and 20 in the passenger compartment fuse box
--C----50 amp---Ignition switch
--D----40 amp---Air conditioner
--E----30 amp---Blower motor
--F----50 amp---Window lift,feeds fuses 1, 3, 6 and 11 in the passenger compartment fuse box
--G----30 amp---Relay module (air conditioning)
--H----15 amp---MEMS relay and inertia switch
--J----7.5 amp--ICE/clock
--K----30 amp---Cooling fans/air con
--L----30 amp---Heated rear window
--M----20 amp---MFU/hand brake/horns
--N----10 amp---Hazard indicator
Passenger compartment fusebox
- Relays (R)
1. Window lift Relay - YWB10027
2. Flasher Relay - YWT10003
--1----30 amp---Sunroof (relays 1 & 2)
--2----20 amp---Heated seats
--3----7.5 amp--Taildoor/Interior lamp
--4----20 amp---RH rear window switch
--5----20 amp---Window control unit/driver’s window switch
--6----20 amp---Alarm ECU
--7----20 amp---LH rear window switch
--8----20 amp---Passenger window switch
--9----10 amp---RH headlamp
-10----10 amp---LH headlamp/main beam warning light
-11----15 amp---Front fog lamp relay
-12-------------not used
-13----7.5 amp--Fresh air circulation/mirror switch/air conditioning
-14----20 amp---Rear wiper motor/Sunroof relays
-15----10 amp---Dim dip (up to 97.5 MY)
----------------MFU/alarm/instruments/reverse lamps/hazard/amps/twin airbag
-16----10 amp---ABS modulator
-17----10 amp---Dim dip resistor (RHD only) up to 97.5 MY
-18----7.5 amp--Multi-function relay unit (starter relay for Rover ECM)
-19----10 amp---RH rear lamp/side, number plate light and illumination
-20----7.5 amp--Multi-function unit
-21----10 amp---RH headlamp (dipped)
-22----10 amp---LH headlamp (dipped)
-23----15 amp---Cigar lighter/radio/clock
-24----15 amp---MEMS/Instruments/speed sensor/relays
----------------Fuel pump (416 Honda Automatic)
-25-----3 amp---SRS (twin)
-26----15 amp---Engine
-27----15 amp---Ignition coil (416 Honda Automatic)
Source : http://forums.mg-rover.org/mg-zs-rover- ... us-811673/" onclick="window.open(this.href);return false;
made By Roverlike
Rover 400 : Fuses, Relays, ECUs
- Dr Doggystyle
- Beheerder
- Woonplaats: het MG-R Forum
