Rover 827Si startprobleem
618 620 623 820 825 827
Roverlike
MG-R Regular
Woonplaats: Split, Croatia
Re: Rover 827Si startprobleem
Bericht door Roverlike »
You see how this metal bar that holds relay looks from the other side?
So you should be able to slide it down without removing the screw. Note there is a small clip in the middle of the metal holder, so you need to jump over it when trying to slide it.
http://www.roverasi.org" onclick="window.open(this.href);return false;
Dick
MG-R Newbie
Woonplaats: Maassluis
Bericht door Dick »
Thanks Roverlike! I asked my friend to try this (he lives in Southern France, where the car is parked). I'll let you know
Dick
MG-R Newbie
Bericht door Dick »
My friend can't get it out. He will ask the help of a mechanic. The ralay is "clicking" when the key is in position 2. He can feel and hear that. That means that the relay is working. But the arrival of 9 V instead of 12V at the fuel pump can still mean that the relay is bad/electrical resistance in the relay?
Roverlike
MG-R Regular
There is also fuel pump relay, which, I think, is located by headlamp, right hand side. Since you have 9V on fuel pump, might be good to see that terminals on fuel pump relay are not corroded and provide higher resistance.
Dick
MG-R Newbie
Bericht door Dick »
Sorry Roverlike, I have been ill and I have missed your reaction. I 'll let my friend look for it. Thanks!
Dick
MG-R Newbie
Bericht door Dick »
My friend checked and did not find a fuel relay behind the right lamp. He only found an aircon system ecu. Next to it there was an emty relay reciever. (but that can't be the problem. The relay has never been there. Another place? A mechanic who has been there thinks its the ignition module (placed on the shock absorver/spring) on the left weel under the hood (hitatchi). As paul carlton said on this forum. Replace it?
Roverlike
MG-R Regular
If you have spare ignition module you can swap it and see if it will solve the problem. Nothing to loose.
Dick
MG-R Newbie
Bericht door Dick »
I don't have a spare unit. I'll try to buy it . at http://www.onderdelenzoeker.nl" onclick="window.open(this.href);return false; (second had). I'll try it also at Rimmerbros.co.uk. Or do you know another store to buy it (second hand)?
Thanks for the help!
Roverlike
MG-R Regular
Actually eBay is my source of spare parts and I have pretty good experiance. However you would need one good replacement for which you know it is working. In such case I am buying new parts.
Dick
MG-R Newbie
Bericht door Dick »
A new one is best bought at Rimmerbros.co.uk?
Roverlike
MG-R Regular
I am using Rimmerbros to compare prices. I see what is part number I need and try to find new one on eBay or somwhere else. If I can get new one for lower price I take it. Otherwise I will take new one at Rimmers.
Dick
MG-R Newbie
Bericht door Dick »
Mechanic/electrician has checked the Rover. The Rover starts , but in 1 or 2 minutes it quits again.
main relay checked; OK
Ignition Module/bobine checked: OK
cable from bobine to power distributor has been replaced. : this cable was burned/there was a short circuit. No solution.
PGM-FI lights up continuously in the dashboard
The electricain asked me for the electral circuit design of this car (rover 827 si 20/8/1992). Any idea where i can find that?
In dutch: Heeft iemand het electrisch schema van een rover 827 si (misschien zelfde voor de hele rover 800 serie uit die tijd)?
AUto start wel, draait een minuut en stopt er dan mee. PGM-FI lampje blijft branden. Ontsteking en bobine en hoofdrelais zijn ok. Bougies OK.
Hij stopt er telkens op onverklaarbare wijze mee. Is iig electrisch probleem.
Roverlike
MG-R Regular
I would recommend one of these, as it may help a lot: http://www.ebay.co.uk/itm/Haynes-Worksh ... 5d703fbc79" onclick="window.open(this.href);return false;
