MG-Rover Club Nederland
Het is nu wo jan 17, 2018 8:12 pm
Alle tijden zijn GMT + 1 uur [ Zomertijd ]
Plaats een nieuw onderwerp Antwoord op onderwerp  [ 29 berichten ]  Ga naar pagina Vorige  1, 2
Auteur Bericht
BerichtGeplaatst: di apr 11, 2017 9:13 pm
Offline
MG-R Newbie
Avatar gebruiker
Geregistreerd: di feb 14, 2017 3:59 pm
Woonplaats: Split, Croatia
You see how this metal bar that holds relay looks from the other side?
So you should be able to slide it down without removing the screw. Note there is a small clip in the middle of the metal holder, so you need to jump over it when trying to slide it.
_________________
www.roverasi.org
Omhoog
 Profiel
BerichtGeplaatst: do apr 13, 2017 7:53 pm
Offline
MG-R Newbie
Geregistreerd: wo maart 29, 2017 11:27 am
Woonplaats: Maassluis
Thanks Roverlike! I asked my friend to try this (he lives in Southern France, where the car is parked). I'll let you know
Omhoog
 Profiel
BerichtGeplaatst: do apr 20, 2017 12:52 pm
Offline
MG-R Newbie
My friend can't get it out. He will ask the help of a mechanic. The ralay is "clicking" when the key is in position 2. He can feel and hear that. That means that the relay is working. But the arrival of 9 V instead of 12V at the fuel pump can still mean that the relay is bad/electrical resistance in the relay?
Omhoog
 Profiel
BerichtGeplaatst: do apr 20, 2017 7:22 pm
Offline
MG-R Newbie
Avatar gebruiker
There is also fuel pump relay, which, I think, is located by headlamp, right hand side. Since you have 9V on fuel pump, might be good to see that terminals on fuel pump relay are not corroded and provide higher resistance.
_________________
www.roverasi.org
Omhoog
 Profiel
BerichtGeplaatst: di apr 25, 2017 10:03 pm
Offline
MG-R Newbie
Sorry Roverlike, I have been ill and I have missed your reaction. I 'll let my friend look for it. Thanks!
Omhoog
 Profiel
BerichtGeplaatst: vr apr 28, 2017 12:49 pm
Offline
MG-R Newbie
My friend checked and did not find a fuel relay behind the right lamp. He only found an aircon system ecu. Next to it there was an emty relay reciever. (but that can't be the problem. The relay has never been there. Another place? A mechanic who has been there thinks its the ignition module (placed on the shock absorver/spring) on the left weel under the hood (hitatchi). As paul carlton said on this forum. Replace it?
Omhoog
 Profiel
BerichtGeplaatst: vr apr 28, 2017 7:33 pm
Offline
MG-R Newbie
Avatar gebruiker
If you have spare ignition module you can swap it and see if it will solve the problem. Nothing to loose.
_________________
www.roverasi.org
Omhoog
 Profiel
BerichtGeplaatst: vr apr 28, 2017 9:37 pm
Offline
MG-R Newbie
I don't have a spare unit. I'll try to buy it . at www.onderdelenzoeker.nl (second had). I'll try it also at Rimmerbros.co.uk. Or do you know another store to buy it (second hand)?
Thanks for the help!
Omhoog
 Profiel
BerichtGeplaatst: za apr 29, 2017 6:51 am
Offline
MG-R Newbie
Avatar gebruiker
Actually eBay is my source of spare parts and I have pretty good experiance. However you would need one good replacement for which you know it is working. In such case I am buying new parts.
_________________
www.roverasi.org
Omhoog
 Profiel
BerichtGeplaatst: za apr 29, 2017 9:47 pm
Offline
MG-R Newbie
A new one is best bought at Rimmerbros.co.uk?
Omhoog
 Profiel
BerichtGeplaatst: zo apr 30, 2017 5:50 am
Offline
MG-R Newbie
Avatar gebruiker
I am using Rimmerbros to compare prices. I see what is part number I need and try to find new one on eBay or somwhere else. If I can get new one for lower price I take it. Otherwise I will take new one at Rimmers.
_________________
www.roverasi.org
Omhoog
 Profiel
BerichtGeplaatst: di mei 16, 2017 8:13 pm
Offline
MG-R Newbie
Mechanic/electrician has checked the Rover. The Rover starts , but in 1 or 2 minutes it quits again.
main relay checked; OK
Ignition Module/bobine checked: OK
cable from bobine to power distributor has been replaced. : this cable was burned/there was a short circuit. No solution.
PGM-FI lights up continuously in the dashboard
The electricain asked me for the electral circuit design of this car (rover 827 si 20/8/1992). Any idea where i can find that?
In dutch: Heeft iemand het electrisch schema van een rover 827 si (misschien zelfde voor de hele rover 800 serie uit die tijd)?
AUto start wel, draait een minuut en stopt er dan mee. PGM-FI lampje blijft branden. Ontsteking en bobine en hoofdrelais zijn ok. Bougies OK.
Hij stopt er telkens op onverklaarbare wijze mee. Is iig electrisch probleem.
Omhoog
 Profiel
BerichtGeplaatst: wo mei 17, 2017 6:54 am
Offline
MG-R Newbie
Avatar gebruiker
I would recommend one of these, as it may help a lot: http://www.ebay.co.uk/itm/Haynes-Worksh ... 5d703fbc79
_________________
www.roverasi.org
Omhoog
 Profiel
Geef de vorige berichten weer:  Sorteer op
Wie is er online
Gebruikers op dit forum: Geen geregistreerde gebruikers. en 2 gasten
Je mag geen nieuwe onderwerpen in dit forum plaatsen
Je mag niet antwoorden op een onderwerp in dit forum
Je mag je berichten in dit forum niet wijzigen
Je mag je berichten niet uit dit forum verwijderen
Zoek naar:
Ga naar:
! .. ! .. ! .... HIER KAN OOK UW ADVERTENTIE STAAN .... ! .. ! .. !
Powered by phpBB® Forum Software © phpBB Group
phpBB.nl Vertaling
